Installation & update
Opening AC in wrong version
KeesW
I have both AC16 and AC15 on my computer and use AC16 mostly. Why doesn't Archicad remember the version last used for the project that I am opening? Time and again a current AC16 project tries to open in AC15 - it won't, of course. And that happens even when I haven't used AC15 for quite some time (unless opening incorrectly is counted). Gggrrr!
Cornelis (Kees) Wegman
cornelis wegman architects
3 REPLIES 3
I always use the right click and open as method just to be sure ...
One other way might be to right click an archicad file pln file, then go to properties > general > change and select Archicad 16.
Hope this works!
Kees
Have you re-installed AC15 recently? It usually opens a file with the latest installed version.
I always open AC first, then select the file to open.
As the file type (mime type whatever) that AC uses is the same for all versions, so the file will be opened by tye version that was installed the last (by default).
On Win You may right click on file and select the AC version to open file, or set the default version that wil be working for double click since.
(You may of course change the right click behavior by editing registry....I use AC versions to AC 12 as the oldest - and I do not need to install AC 12 - so I copy the installed version - and than I add the proper registry entry so I can right click to open with AC12).
Best Regards,
Piotr
Learn and get certified!
