Installation & update
PNE Files
Dear community,
back in 2000 I used ARCHICAD on Windows 98 to design my farm. Is there a way to convert the PNE files into a new format which can be used today?
Thank you very much
Marc
1 REPLY 1
Eduardo Rolon
PNE files were created by using the EDUCATIONAL Version of AC this file type stopped working with the release of AC10 if I remember correctly and the only way to open them is to reinstall the EDU version from that time and even then you will not be able to "save as" any format that can be read in any modern version of AC. You might be able to export the 2D layouts as DWG and the 3D as 3DS or OBJ but they will not be AC native objects.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
