Installation & update
SOLVED!
Pixelated image 2D& 3D Archicad 23
Hello! I have a problem lately with my Archicad 23. It displays the image very pixelated and I don't know why. Is my graphics or I need to do some settings? It does the same thing in 2D and in 3D. Even if it's not very heavy the file. I also have the same problem with AutoCAD, but it more rare. I also use PS, sketchup, Lumion and V-ray and those programs work fine.
1 ACCEPTED SOLUTION
Solution
Lingwisyer
Guru
I have had issues that look similar to that in the past caused by shoddy display cables.
2 REPLIES 2
runxel
Legend
Pretty sure that this a driver problem. Update your graphics driver.
Also make sure you are using the dedicated graphic card and not the integrated Intel one, if you happen to be on a notebook.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Solution
Lingwisyer
Guru
Learn and get certified!
