2004-01-22 01:32 PM
Solved! Go to Solution.
2004-01-22 09:54 PM
Tanny wrote:As far as I know (AFAIK), the only problems with HP plotters are the lack of factory drivers. I've been using GimpPrint with my HP 488CA for a few years with virtually no problems. With Panther, of course, GimpPrint is built in, but since Retrospect is not yet Panther compatible (due out Monday), I haven't switched to 10.3, so I can't help there. Check the GimpPrint website @ http://gimp-print.sourceforge.net/MacOSX.php3. The new alpha version 5.0.0, though not completely stable, suredly supports most all HP plotters. The website has all the info, including supported machines.
According to the HP website, none of their wide format plotters will work with OS 10.3.2 specifically. I've tried the HP 120nr which is suppose to be fine for "10.2.1 and higher", with the most recent driver and none of the plotter settings were available. What is AFAIK?
2004-01-22 07:19 PM
2004-01-22 08:02 PM
Matthew wrote:According to the HP website, none of their wide format plotters will work with OS 10.3.2 specifically. I've tried the HP 120nr which is suppose to be fine for "10.2.1 and higher", with the most recent driver and none of the plotter settings were available. What is AFAIK?
AFAIK most plotters and wide format printers will work with OS X. Which have you looked at?
2004-01-22 09:54 PM
2004-01-23 09:07 AM
2004-01-23 10:36 AM
Matthew wrote:Matt,
Actually we have a problem with our HP1050c BECAUSE ther is an HP driver. The trouble is that it doesn't work (reliably anyway) and so there is no open source alternative. Fortunately our lease term is up so we are looking at other machines. I am particularly interested in the Epson 7600. If we end up getting it I will post our experiences.
2004-01-27 08:54 AM
Tanny wrote:I don't know if you ever made any progress, but you might check the pulldown in PlotMaker's Plot Setup and see what is listed under the different vendors. We too are using our old HP750C. It was very tricky when OS X first came out, but X.3 handles the device better.
I'm having difficulty finding a plotter that will work with OS 10.3.2. I am using a Power Book G4, and ArchiCad 8.1. I want to be able to plot onto 2' wide media. Colour is not essential, but it would be nice.
Has anyone found anything that works?
