Installation & update
Problem installing my ArchiCAD 17
I am Elvin. Currently study in UK. I cannot install my ArchiCAD 17.
Im using Asus N56VZ which operated Windows 8.1.
At first when i install my ArchiCAD, it will stop at the page in attachment 1.jpg .
I try to click next but still in the same page.
Then I let my PC open the whole night (approximate 8 hours), but still nothing happens.
So, I restart my PC and install again, this time it can install but stop at 1%.
It show successfully install but I open C:/Program Files/Graphicsoft, inside only got a log file which is a txt log file.
(Oct 31, 2013 8:44:43 AM), Install, com.installshield.product.actions.UninstallerJVMResolution, err, JVM resolution timed out
(Oct 31, 2013 8:44:43 AM), Install, com.installshield.product.service.product.PureJavaProductServiceImpl$Installer, err, ProductException: (error code = 601; message="JVM not found")
STACK_TRACE: 8
at com.installshield.product.actions.JVMResolution.install(JVMResolution.java:171)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.checkUninstallerJVMResolution(PureJavaProductServiceImpl.java:1015)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.install(PureJavaProductServiceImpl.java:1283)
at com.installshield.product.service.product.PureJavaProductServiceImpl$Installer.execute(PureJavaProductServiceImpl.java:219)
at com.installshield.wizard.service.AsynchronousOperation.run(AsynchronousOperation.java:41)
at java.lang.Thread.run(Unknown Source)
Please help me figure it out since I need it to complete my assignment.
Thanks
1 REPLY 1
You say that you look in C:\Program Files\Graphisoft ... but your screenshot shows a customized installation to not install there, but rather to C:\ArchiCAD 17
What's inside your C:\ArchiCAD 17 folder? What happens if you let the installation go to the default location (which you wrote): C:\Program Files\Graphisoft ?
Did you suspend your antivirus software during the installation?
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
