Setup & License forum
Problems with extracting .lcf file
I originaly posted this in the ACE Library topic but now that I tried some new stuff I think its worth asking again.
I'm having issues with extracting a library in the LCF format to get all the parts in folders so I can fiddle with it a bit. I tried using the "extract container" command but in the target directory I only get 4-5 folders out of the supposed 35 or so.
I have the exact same result with saving as PLA and extracting to a folder upon opening the file, only a couple folders get there.
Do I need to close any AC open with that library active before I extratc? I tough that the PLA method wouldnt need to.
Anyone have an idea about this, im a bit desperate.
Thanks in advance, and sorry for sorta doubleposting.
13 REPLIES 13
andyro
It's a mac/pc thing. You ought to download the PC version. XP/Windoze machines can't deal with some of the 'funny european' characters and decide to go on strike when they see them, which is why extraction aborts.
Andy Thomson
Andy Thomson | Architect
Research site
Company site
AC24 / Twinmotion / iMacPro
I have never had any luck trying to extract the ACE library.
And I do have the PC version.
This is all that extracts - just tried again in version 13 as well.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Compared to what there should be.
Versions 6.5 to 25
vistasp
The same happens here and presumably on all PCs. I would love to have a zipped (instead of lcf) version of the ACE library so that I could choose what object I want to load. Of course that would mean having to deal with macro dependencies... 😉
Any chance of a zipped version Andy?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-26 INT | Win10 | Ryzen 5700 | 32 GB | RTX 3050 |
andyro
It's not the lcf that causes the problem afaik - it's the umlauts etc. in the actual objects that cause the unpacking to fail - I tried lcf and zipped versions when I created this. I had to manually rewrite every offensive character on a mac when I made the pc version - and my pc version loaded fine - unfortunately - I don't have any time to dedicate to this project right now - but I would suggest working between a mac and a pc to discover this current problem - are you sure it was the pc version? The torrents have been re-seeded hundreds of times by others...
A
Andy Thomson
Research site
Company site
When you extract it, you might want to choose a folder high in the root. So don't choose some folder in 'my documents' but in 'c:\'
Hope this helps.
vistasp
I'm certain it was the PC version Andy but will redownload tonight just in case. Whether I succeed in extracting the entire lcf or not, I just want to say many many thanks to you guys for having created this library in the first place.
Masterscript, I'll give your suggestion a try first - might save me some precious bandwidth!
= v i s t a s p =
bT Square Peg
vistasp
Nope. Didn't work.
Masterscript, the result of extraction is exactly as before regardless of whether it's to a root directory or not.
Andy, I tried with a fresh download of the PC version but no dice.
Giving up...
= v i s t a s p =
bT Square Peg
Erika Epstein
Could someone point me to the download for the international version?
Thanks
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
vistasp
For the ACE library Erika? As far as I know, there's no International or US version - just Mac and PC versions. They're both here.
= v i s t a s p =
bT Square Peg
Erika Epstein
Hi Vistasp,
Thank you, but I am trying to find the 13 INT mac library.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
vistasp
Ah! Was wondering about that, but given the subject of this thread...
Sorry, don't have the link but then I haven't received my copy of 13 yet! According to my reseller, they're starting to roll out the INT version after the Hungarian, US & Australian. I'd have thought the INT version which is most widely used would have been first out of the blocks.
= v i s t a s p =
bT Square Peg
ztaskai
Graphisoft Alumni
Graphisoft Alumni
I'd like to highlight a very good suggestion from Master Script.
When extracting an LCF on windows select a target folder with a short path. Unfortunately, Windows has a path limit of 255 characters. Let's take an example. You can have an extracted library at 'D:\MyFavLib\', in which the longest path reaches to 240 characters. Now you pack it and send it to your buddy in a neat LCF. He then extracts it to 'F:\Works\Useful Libraries from Peers\2009\Jacks Sanitary Lib\' and all elements will get lost which extend beyond 255 characters. It's even worse if you have a Mac and he has a PC because in this case you may have used paths far beyond the 255 limit...
So when you don't know where the LCF came from, you should extract it to a short path and copy the extracted folder in Windows to the final location. This way Windows will let you know when it encounters a problem while copying.
Unfortunately, Barry has a different problem which I don't know...
Regards,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
