Check the geometry settings of the label.
Is it set to be 'Associated' and is it set to 'detailed' rather than 'simple' so you can control the pointer position (assuming you have the pointer turned on).
Otherwise can you explain what is not placing properly?
What is happening?
Do you have an existing label that has already been placed?
If so, ALT-click it to get its settings (pick up parameters - pipette).
Then try placing an new one.
That way you know you are working with label settings that did work.
