2020-09-25 12:31 PM
Archicad 4.55 - 25 | HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Nvidia Quadro M5000 @ Windows 10 Pro x64
Solved! Go to Solution.
2020-09-30 02:01 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-28 02:17 AM
Minh Nguyen
GRAPHISOFT
2020-09-29 08:13 AM
2020-09-30 02:01 AM
Minh Nguyen
GRAPHISOFT
2020-11-22 07:49 AM
2020-11-23 06:08 AM
fabioferrini wrote:Dear Fabio,
Same issue here,
on Mac OS 10.15.7 AC crash randomly when I try to publish .BIMX; .DWG, very frustrating!![]()
Fabio
Minh Nguyen
GRAPHISOFT
2020-11-23 07:08 AM
2020-11-23 08:38 AM
mnguyen wrote:Thanks for your interest, mnguyen:
Same issue here,
Fabio
Thank you for the report and I am very sorry about the issue!
Is there a stable way to reproduce the crash? Also, does it happen even with a blank file, or with some specific files only?
I'm wondering if you keep a copy of the sent bugIDs? If not, all IDs of the sent crash reports are recorded in a file called SubmissionLog.txt. This file is located at:
On Windows 10: C:\Users\<user>\GRAPHISOFT
On macOS: <user home>/Library/Logs
With the bugID, I can run a quick check to see whether the crash is linked to a known issue.
Best regards,
Minh
2020-11-25 06:54 AM
Minh Nguyen
GRAPHISOFT
2020-11-26 03:07 AM
2020-11-26 03:27 AM
Minh Nguyen
GRAPHISOFT
2021-02-02 12:32 PM
2021-02-03 12:33 AM
DaphneTsl wrote:Hello,
I am working on a project in AC23 and Publisher crashes during publishing layouts to a single .dwg file, giving me the bug reporter.
The strange is I used to publish successfully, until I made some serious changes in the Layer Combinations of the project and created Ceiling Plan/Lighting Plan Views, etc. I have no problems when publishing to a single PDF file, or when I export a View/Layout to DWG separately.
If anyone knows how to deal with it, please help me. I have tried to do all that have been mentioned above, but didn't work.
Thank you in advance,
Minh Nguyen
GRAPHISOFT
2021-02-03 02:32 AM
2021-02-03 05:17 AM
Minh Nguyen
GRAPHISOFT
2021-02-03 07:32 AM
2021-02-03 07:34 AM
Minh Nguyen
GRAPHISOFT
