Installation & update
RFA & RVT Geometry Exchange Add-On
JessicaBoll08
I keep getting the notification that my RFA & RVT geometry exchange is not up to date. The latest update is : Build 4015. I download the update and when I go to install it it says RFA & RVT Geometry Exchange Add-On for ARCHICAD 24 is already installed in the selected folder. How do I make this update work?
Version: 24.0.0
Build Number: 4018
Library Build Number: 3001.6
Eduardo Rolon
You need to uninstall the previous version. Go into Graphisoft -> Archicad -> Uninstall.RIO and double click on the uninstall app. That will uninstall the previous version.
FYI DO NOT USE the one under Uninstall.AC
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Just to clarify it for anyone interested:
The "Uninstall.AC" folder contains the uninstaller for Archicad (hence "AC").
The "Uninstall.RIO" folder contains the uninstaller for the Revit Input/Output Add-On (hence "RIO").
