2012-06-12 12:45 PM
2012-06-12 12:56 PM
2012-06-12 01:11 PM
2012-06-12 06:51 PM
aahatimo wrote:Yes, see here
Will graphisoft optimize ac for such a display...?
2012-06-12 08:19 PM
ejrolon wrote:
FYI 17" has been discontinued.
2012-06-13 01:22 AM
2012-06-13 09:23 AM
2012-06-15 01:31 PM
2012-06-17 02:49 PM
2012-06-18 06:10 AM
Erich wrote:Here is mine for AC 12 (as per your signature) on a 15" MacBook Pro. The Menus Scheme is based on older AC, but that can easily be replaced. This should give you a quick start.
Does any one have a good, well functioning WE for a 15 inch screen?
2012-06-19 12:58 PM
2012-06-20 05:48 AM
Erich wrote:Here it is (don't understand why it disappeared).
I got to the party a bit late it seems. I'm getting a message that the attachment cannot be found. Can you repost? Thanks.
2012-08-16 02:14 PM
2012-08-16 07:54 PM
2012-08-25 07:52 AM
2012-11-28 12:38 PM
2013-02-04 01:28 AM
2013-02-04 08:50 AM
stefan wrote:...and don't forget that the one remaining USB port is now your ONLY USB 3.0 port, as the Cinema display (even current models) is only USB 2.0 So, if you have an external USB 3 disk you need to use that one remaining port if you want full speed... or get a USB 3 port hub, which starts to make the entire 'docked' setup a tangle of wires and devices...
Having only 2 USB ports is a problem. Luckily the adaptor uses the Thunderbolt port, so after connecting my Display (power - thunderbolt and one USB) and Ethernet (the second thunderbolt), there is only one USB left (to the right of the machine).
