Installation & update
Select Dimensions Disapearing
I will have to describe the issue because i didn't think to get a SS, I just want to see if anyone has heard of or run into this issue.
Working on a floor plan and the running dimension lines randomly only are showing every other dimension point. For example window to window it would read 14'-0" but it should be dimension the window and wall space which should be reading 6'-0" and 8'-0". But if I grab the dimension line and move it to force the line to update it fixes it. Sending and receiving did not update the line. I had to do this on multiple lines and one of my co-workers said she had the same thing happen in another project so it isn't something in this specific file.
4 REPLIES 4
Can you post before-after images?
Since I didn't think to Screen Shot it till after the issue was fixed, I just made a quick example of what it looked like. The left is what it is supposed to be; the right is what it looked like before I forced the dimension line to update. I didn't actually change anything I just selected the line like I was moving it, put it in the same location, and it fixed itself. But, I had to do that to every dim marker that was having that same issue.
I see.
I have no idea why this is happening or what could be done to avoid it.
So I will report this to Graphisoft for investigation.
Katalin Borszeki
Hi, since so far we did not get an answer from GriffinDWolf, we couldn’t investigate the issue more deeply.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
