2021-06-08 06:51 PM
2021-06-09 03:19 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win10 | R5 2600 | 16GB | GTX1660 |
2021-06-09 03:59 AM
2021-06-09 02:57 PM
2021-06-09 08:23 PM
Erwin wrote:He's running mac, tho
You could try running it in compatibility mode for windows 7. For this right click the archicad 10 executable and go to properties and find the compatibility tab.
2021-06-09 10:56 PM
2021-06-09 11:06 PM
FNoyes wrote:No problem with shift-option on 10.11.6 and ARCHICAD 10. Hope none of this is Mojave, but it could be... as ARCHICAD 10 is 15 years old. The only other thing I can think of is that you have some Accessibility feature (System Preferences) turned on which is altering the way that modifier keys work (Sticky Keys for example).
In addition, it is not possible to move the project origin using the key pad (Shift, Option).
2021-06-10 08:47 AM
runxel wrote:Yes, I read AC10 and that somehow warped to WIN10...
You could try running it in compatibility mode for windows 7. For this right click the archicad 10 executable and go to properties and find the compatibility tab.![]()
I think you're out of luck, my friend! ...
Mac updates kill a lot of software regularly.
2021-06-10 01:49 PM
Karl wrote:FWIW, I can run AC10 on my MacBook Pro running Mojave (10.14), it is 10.15 that breaks a lot of older software. I am not seeing the problems the original poster described.
2021-06-14 08:58 PM
