Installation & update
Thick lines in 3d, unable to select
Is there a solution to this issue? when working in 3d and zooming to the element (for example, trying to select the corner point), blue reference line becomes way to thick. It is almost impossible to navigate in that scenario. Is there any solution to always render line thickness same width, regardless of the zoom?
1 REPLY 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Petar,
Thank you for the question and I am very sorry about the experience!
Unfortunately, it is not possible to edit the reference line thickness.
However, if we set the Snap Guides on and position the mouse next to the desired corner, a blue circle will appear to assist accurate selection and replacement. Please find the Help Center article below:
https://helpcenter.graphisoft.com/user-guide/127969/
Please let me know if it helps with the issue!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
