In the attached image, a window is placed over a door in a 12' tall wall. The floor cut plane is at 4', door is set to symbolic fl.plan display and the window above is set to projected fl.plan display. One would expect the door to be visible with the window not (as it does not pass within the FCP). However, the door symbol takes on a hybrid condition where appears both symbolic as well as projected (when in the floor plan view, but appears correctly in elevation and model).
As a work-around and to get the drawings out, the window has been reset to symbolic and assigned a pen number with a value of 0 mm thickness, which does not print/plot.
Any other thoughts will be appreciated.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
