You should be able to update your key on any machine that has the license manager software.
Once updated it will be fine to use on any machine.
Maybe your Windows 10 server just needs an update for the license manager software?
I would have thought that if LM can't see the key on that machine then your BIM server software will have the same problem.
Or maybe there is a problem with the USB port?
