2014-05-12 05:31 PM - last edited a month ago by Aruzhan Ilaikova
2014-05-12 06:16 PM
2014-05-12 06:28 PM
2014-05-12 06:33 PM
mc0m wrote:That has to be illegal software at that price, or else they are over-charging for the free-to-all software but without a WIBU/Codemeter license key. Since the software is delivered digitally, it is most likely 'cracked' to run without a keyplug = illegal. When so-called 'cracked' software is installed, it typically will not be recognized by the update procedures from Graphisoft and so no hotfixes can be applied, leaving you with whatever bugs exist in the (illegal) version obtained.
For instance - is it kosher to buy AC 15 from this vendor (or another vendor like them)?
[moderator deleted]
Then do you buy something from Graphisoft that changes your WIBU key?
And is 15 the version I should be considering? Are there other versions that provide better support for what I do? (Modeling historic objects in detail ...)
Or am I going down the wrong path altogether?
2014-05-12 06:55 PM
Karl wrote:Graphics card: ATI Radeon HD 5870 1024 MB
What are your graphics card specs - model, amount of memory? That's the main thing for OpenGL.
2014-05-12 07:07 PM
Karl wrote:Now I am totally depressed.
Only Graphisoft can upgrade your WIBU/Codemeter key to work with any newer version of AC...and I'm not aware of any offer that they have to do a partial upgrade. They would upgrade you to 17... and then you could choose to use 15 (key is valid for any lower version at all times).
You can bug a legal key (new keyplug) from a licensed owner of AC 15... but then if you ever want to upgrade in the future, that other key has to be re-registered in your name with Graphisoft involving a steep 'transfer fee'.
2014-05-12 08:33 PM
mc0m wrote:You should have no problems at all with this card and the other machine specs that you list.
2014-05-12 09:13 PM
2014-05-12 09:42 PM
2014-05-12 10:45 PM
