Installation & update
Vanishing cursor: bug?
This strange phenomenon happens to both me and my colleagues with annoying frequency:
In a model view, the cursor suddenly seems to turn off. The mouse position is visible, but the frame of the drawing window or marquee is invisible. Icons at snap points disappear, and dimension marks don't appear when clicked. Anchor points of walls or fills don't appear - although you can still draw them if you're prepared to work 'blind'.
I find that, if I open a layout and then go back to the model, the problem has gone away.
It seems to happen when I'm doing a lot of stuff in a hurry. A lot of zooming in and out. Could I be inadvertently clicking a short-cut that invokes this effect? Or is it a bug? Does this happen to anyone else?
Keith
AC11 on
MAC 0S 10.4.8
12 REPLIES 12
Thomas Holm
The S key is the shortcut for Grid Snap. Looks like that's your problem.
I have it happen more than once... (3D window - perspective mode / Open GL).
From what I've been testing lately, the frequency seems to depend on the amount of SEO that were used in the project. The more I have my plans detailed with wall-slab-roof intersections, the more I get this behaviour.
I always save, quit and re-open to solve this...................temporary.
No Thomas - I've experienced that one as well, and have removed the shortcut to the grid snap. This is different. Zoom window disappears as well.
- K
I have seen this occasionally on Windows but not on Mac. In those cases it seemed to be a display driver issue.
I don't think it was ever a problem in Release 10
Laura Yanoviak
It's happened to me sporadically (maybe 6 times in 3 years) using AC9, AC10, and AC11.
AC26 US (5002) on Mac OS Ventura 13.5
sarahric
Any update on this. I'm using 16 and having this problem more and more. Restarting projects 5 or 6 times a day.
Have recently updated the graphics driver.
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
Streamline JG
Beginner
We are having a very similar issue, also happens when working rather quickly with lots of zooming and panning in plan view.
Specifically, the cursor tends to turn into the "hand" icon permanently, and therefore doesn't show snap icons/etc.
The only workaround I have found is to open the 3D window and pan the 3D view around. Then the cursor returns to normal in 2D. Sounds like a simple fix, but I often don't have a 3D window activated and it takes several seconds to bring one up. It happens several times a day and is one of several bugs in AC16 that has had a huge negative impact on our productivity.
NCornia
You may want to visit Options/Work Environment/Advanced Redraw Options and adjust your settings. Often disabling antialiasing in 2D will help or
increasing the amount of Hardware acceleration (learn more here).
If you have Trace Reference enabled, please refer to this article: http://www.archicadwiki.com/Troubleshooting/SlowTraceReference
Lastly, you should try saving your current Work Environment and then use the Standard Profile 16 to see if that clears up the issue.
Applying Work Environment Profiles
HTH
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Learn and get certified!
