Installation & update
Version/build of one or more modules are not compatible
I have installed both hotfix AC15 hotfix-2 and AC14 hotfix-6 on my mac but I get this message each time I lunch AC...
After clicking "OK" AC opens and runs normally, but why do I get this?
Mac OSX 13.6.4 | AC 26 INT 3001 FULL
11 REPLIES 11
Didn't You install eg. a goodie after updating AC?
Best Regards,
Piotr
No, I didn't.
What hapens if You run the hotfix again?
Best Regards,
Piotr
I can't... I get the message: "This Archicad has already been updated"
Erika Epstein
if you continue to the next page of the installer, it gives you the option to update other components of AC, did you do that?
Also, it mentions modules that may be out of date. Sometimes you have to manually open each module when AC has been updated before it recognizes them as being of the latest build.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Erika,
I tried your suggestion, but the next page of the installer doesn't give me any other components to update... just the remote BIM server... which is updated
As for the modules, the message appears when I launch AC before selecting any file to open. As a matter of fact the message appears right away, and after I click OK, the open file window appears
Erika Epstein
Hi Achille,
Well, at least the file is opening.
Is it only on your computer?
Did you try repairing permissions?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Hi Achille,
we have an ArchiCAD wiki article about this issue: www.archicadwiki.com/Bugs/HotfixInstallWarningMessage
It describes the cause and the solutions as well, please check it.
Best regards,
Katalin Takacs
Thanks Katalin!
Maybe this is caused by the fact that the user home folder is actually on the server HD and not on the local drive?
(even though every one else's user home folder is on the server too, but only I had this problem...)
