Setup & License forum
WIBU for Arch v9 32bit on 64 bit Windows?
Have been trying unsuccessfully to install v9 32bit on a 64bit xp os. The software will install but I cant get the key to work. Any ideas?
Looks like I will have to upgrade OS anyhow so will v9 work with Windos 7 pro or higher? Thanks for any help!
1 REPLY 1
It should run under XP 64... must be just a WIBU driver issue. The 32 bit and 64 bit drivers for AC 9 are here:
http://www.graphisoft.com/downloads/protection_key.html
But, see also this old thread on the same topic:
http://archicad-talk.graphisoft.com/viewtopic.php?p=181288
If you upgrade to Windows 7 Pro as you suggest, note the issues in this article:
http://helpcenter.graphisoft.com/technotes/operating-systems/windows-7/
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
