Installation & update
Wacom Mouse - orbit in 3D
Hi!
Does anyone know if there´s a way to orbit in 3d view with a wacom mouse (intuos 3) ?
It´s a bit backwards, workflow wise, having to swap mouse everytime I´m in Archicad...
Hoping for a solution...
Thanks,
Haavard
3 REPLIES 3
Dwight
I use a Wacom mouse against an Intuos tablet.
Works fine for Orbit.
What is wrong with yours?
Dwight Atkinson
When I go into 3d explore it´s almost imposible to navigate. The slightest touch on the mouse can take me lighyears away from the point where I actually want to be...
Maybe there are some settings that I´m not aware of?
With a normal mouse it works like a dream, but I would really like to make it work with the wacom as this is what I use for everything else.
Dwight
I have this overfast experience with Cinema 4D and its lovechild Maxonform. Maxon has a special tablet setting to fix.
But never in Archicad.
Attached are my settings for Archicad with Wacom. Set as fast as possible, considering the circumstances.
I suggest you check your mapping to cover as large an area as possible and also to force your mouse to mouse mode and not pen mode.
Dwight Atkinson
Learn and get certified!
