Why do I keep getting this Pen symbol instead of a number?
Brad Elliott
I keep getting this pen indicator in my info box. This creates a half tone pen that I then have to select and change to a real pen. How can I avoid this happening?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
8 REPLIES 8
What is it the pen setting for?
All elements (tools) or just one in particular?
Brad Elliott
Line tool mostly but occasionally for fills as well.
M1 Macbook Pro
I have never seen this.
So are you saying that if you fix it with a proper pen, it will revert back again later while working on the same file?
If not then somehow the default has become corrupted and just needs to be reset and the file saved.
Then hopefully it won't happen in that file again.
If you ALT click on an existing line, does it reset the tool default settings?
Brad Elliott
Barry,
Once I change it to a proper Pen number it will keep it. I seem to keep running in to it on different lines. I can transfer the settings from a different line.
The drawing was started from scratch in this file and nothing from the outside has been copied in. I'm also only working in one pen set. This is a remodel so I am using the renovation filter but that doesn't seem to matter as some of the lines are existing and some are new and changing their state doesn't change the line.
I have added a couple more screen shots for reference. You will notice that the open pen box shows a non existent pen 256.
M1 Macbook Pro
I have never seen this extra pen and have no idea where it may have come from.
The only extra pens I know of are for fill backgrounds (pens 0 & -1).
I have also seen an RGB pen for zone fills, but never a pen 256.
There is no option to even click on pen 256 for me - there is just nothing there.
If it is just in this one file then I would suspect some sort of corruption in the attributes.
Actually it would be interesting to see what is listed in the attributes for the pen sets.
Is there a pen 256?
I am guessing nothing will show as pens 0, -1 and the RGB pens do not show in the attribute manager.
James B
You'll sometimes see this pen, when it's a custom RGB colour that's not in your Pen Set.
For example, copy a shaded element from an elevation, paste into floor plan. The fill will use this custom RGB pen.
But I haven't seen that pen icon appear before myself (only the RGB wheel). Maybe related...
James Badcock
Graphisoft Senior Product Manager
Greg A_ Blunier
I get the "custom" pen as well. It seems to occur for me most if I use the eyedropper to sample an existing line that is being "overridden" either by a renovation filter or a graphic override.
ArchiCAD 22 USA Full and ArchiCAD 7
Windows 10
Minh Nguyen
Hi All,
I hope you are doing well during these trying times.
Thank you, Brad, for sharing this issue! I have never seen this Pen symbol appearing to me. I haven't found it reported to our database either, therefore this must be a rare issue.
I exported the attribute to an XML file and edit it to include a pen #256, still I cannot import the #256 pen to the current file. As Barry suggested, can you see the pen #256 in the Attribute Manager?
Could you share a sample file for a closer look? Thank you very much and I look forward to hearing from you soon!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
