Setup & License forum
Why i can't sign up in Archicad Software?
Agon Sasdiku
Hello everyone,
I recently got Archicad 25 and while i wanted to publish a bimx hyper-model , so i can share my project to my friend, but while doing  so , it is necessary to sign in to my graphisoft ID, and when i clicked sign in , a blank dialogue window pops-up and nothing happens.
Also , when i first open the software, its trying to get me to sign in, but nothing happens and then i have to click skip sign in , in order to proceed working with my projects.
Pleas help me!
Minh Nguyen
Graphisoft Moderator
Thank you very much for the screenshot!
This issue is similar to one of the reports we had: if you have an Intel Iris Xe graphics card, it could be the case. I would like to ask for a System Information file (How to Save System Information of Your Computer) for further checking.
Please try to update the driver to the most recent version, and see if the issue gets resolved if you have this type of card.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
15 REPLIES 15
So you have a Graphisoft ID and you know the sign in name and password?
But when you enter the information and press login, nothing happens?
Can you try accessing https://graphisoftid.graphisoft.com/ with different browsers to see what happens?
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Agon Sasdiku
Hi Barry.
Actually , i dont have any problem with my graphisoft ID or my browser.
The problem is within the software of Archicad. Im trying to sign in from the software, not from my browser.
Each time when i click  'sign in' , i just get a blank window and nothing really happens. So literally i dont even have the chance to enter my ID information.
Thank you.
DGSketcher
@Agon Sasdiku  Are you using Publisher? If so, in Publishing Properties have you signed into your account?
How to: Create BIMx Hyper-Model from Publisher
Apple iMac macOS Monterey / AC25UKI (most recent builds)
There is no problem with the publishing part, its just that i can't sign in in general. I cant type in my ID information. I think the problem has to do with the software , maybe a type of glitch or bug, i don't know.
Here is a screenshot where the log in window its just a frozen window with some of the lines supposed to be the input space for your ID info, but most of the time this window its just blank. I can't type in anything on this window
OleRye00
I have the exact same problem
Minh Nguyen
Hi All,
Thank you very much for the report and I am very sorry to hear about the issue!
First, I would like to check whether there might be any problem with antivirus/firewall software blocking the connection to our server? Can you sign in with your browser using the following URL: https://graphisoftid.graphisoft.com/
If yes, then there might be a problem with the sign-in window inside Archicad. At the startup dialog, there is a similar window if you click on the top right corner button (Sign in). Does this window work for you?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Hi.
I have no problem with signing in when I click the link. The problem is signing in in the program. I can't sign in in the startup dialog or inside Archicad so neither of them work.
Best regards
Ole Andreas Rye
Minh Nguyen
Hi Ole,
Thank you for the confirmation!
I'm wondering if you try to sign in inside Archicad, is there anything loaded, or you only see a white screen?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
OleRye00
Hi.
Usually there is nothing but a white screen but some very few times it loads. But when it loads, I can't type in my e-mail or password. I addded a screenshot here to show you how it's like.
Best regards
Minh Nguyen
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Thank you for the answer!
I have an Intel Xe graphics card and it worked when i updated it.
Best regards
Ole
Minh Nguyen
Great to hear that!
Have a nice weekend!
Minh
Minh Nguyen
GRAPHISOFT
Thank you very much, now it worked.
God bless you !
We use a different workflow: publish the BIMx file to server or local storage and sign in to the bimx portal and upload the file.
I'm sure your method should work as well, but at least this way you can share the file.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
