Setup & License forum
Window tabs not appearing in AC20
Liamthanks
Hi all,
Recently started a new job and I have been setting up my workstation to suit my preferences. For some reason, I cannot work out how to display the window tabs in AC20. I pulled my WE from home and imported it onto the work PC, but they have still not appeared.
Any suggestions would be great, not a fan of constantly going back through the navigator to swap between windows / tabs.
AC24 Build 7000 AUS - Windows 10 Pro, Ryzen 7 5800X, Radeon 5700 XT, M.2 NVME 0.5TB SSD, 32GB RAM
4 REPLIES 4
It is actually not a WE setting.
Go to 'Window' menu and 'Show Tab Bar'.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Liamthanks
Hey Barry,
Cheers for the quick response, however I don't see that option for some reason?
It should be there.
I would say that you are using a custom Work Environment from an older version of Archicad that didn't have this command.
You can either add it into the menus yourself or load the default Standard Work Environment.
If you are using an old custom WE, you are probably missing a few other menus and toolbars as well.
Versions 6.5 to 25
Liamthanks
Thanks Barry, resetting the Work Environment and then applying my settings did the trick!
