Work slow Archicad 23---Procesor i7 10700k bios configuration ?
Hello
I have a PC with
Asus Prime z490-v motherboard
Intel (R) Core (TM) i7-10700K CPU processor @ 3.80GHz
32 ram ddr4
nvidia Quadro k5200
500gb ssd
the problem is for large projects over 400 mb it no longer works properly the processor is at 100% and the section and elevations do not work at all or work very hard
is there a problem in the bios?
or what are the perfect settings to use Archicad 23
if you know please help me
thanks a lot
1 REPLY 1
Minh Nguyen
Thank you very much for the question and I am very sorry about the issue!
Based on the specification alone, your machine can handle models much larger than 400mb!
I believe there must be some corrupted elements inside your file that triggered some sort of CPU/memory problem. I am wondering if you are willing to share the file for a closer look? Please let me know if you need a secure place to upload the file also!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
