ac9 hotfix update not working so hot
archicad 9 crashes without any error message after i do things like saving and 3d navigation. no matter what it crashes in 5 minutes after opening any file. i checked for updates and it isn't up to date but when i try to install the update it says i need to update java or install it from the hotfix CD. I'm not sure what hotfix is but i used the archicad installation CD and installed the java runtime environment from there. i also updated java from the internet. i rebooted and tried to update archicad again and i get the same message.
Dell Dimension 2400
Pentium 4, 2.8 Ghz
1 GB ram
Intel Extreme Graphics
4 REPLIES 4
I've deleted your duplicate post.
What OS?
One of the forum moderators
windows xp professional 2002 sp2
Hmm. Shouldn't be a problem then...
Note that all software on the 9 installation CD is "ancient" - whether it is java, WIBU or whatever. So, not surprising that you would have to download a java update.
Since you are a US user, go to the US tech support web site:
http://tr.graphisoftus.com/
where you can click on ArchiCAD 9 and download the build 2219 hotfix; the installation guide there might also be helpful.
Will this hotfix install? If not, what message(s) do you get when you run it?
Under Utilities on the same web site, you will find an updated WIBU driver. Try that if necessary.
Review AC 9 articles on the Wiki:
http://www.archicadwiki.com/Archicad_9
Your crash could be related to QuickTime 7?
http://www.archicadwiki.com/Bugs/When_QuickTime_7_is_installed%2C_ArchiCAD_crashes?highlight=%28Bugs...
This other AC 9 crash:
http://www.archicadwiki.com/Bugs/Crashes_with_ArchiCAD_9_%28build_1812%29_INT_on_MAC_when_opening_ol...
was fixed by an earlier hotfix, so will not be an issue once you update your installation to build 2219
And, of course, consider contacting US Tech Support and/or your reseller if this is time and mission critical.
i reinstalled archicad after i uninstalled all versions of java...then i could download the hotfix...of course i lost my custom work environment in the process but that's just how it goes.
