Strange.
Changing to Axonometric shouldn't make elements disappear.
They may not be in view but fit to window will fix that.
If you 'select all' (CMD+A on mac?) does anything select?
Does it make any difference if you change from the OpenGL engine to the Internal (Vectorial) engine?
If you select a single wall or column and view just that in 3D do you have the same problem?
Does this happen in all files or just this one?
