Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1378 Views
  • 6 replies
  • 3 likes
Archicad 20 not starting-up
Good afternoon everyone, I've been running into a big problem regarding booting Archicad. My desktop pc isn't able to boot up archicad further then the first window (screenshot is added) anymore. It did however run fine a couple of months ago. My lap...
Anonymous by Not applicable
  • 2660 Views
  • 7 replies
  • 0 likes
Renovation filter over ride
Can't seem to get the changes I make to the renovation filter graphic override to take effect. Have checked to be sure that the override is on in the view, but it seems to make no difference. The changes I make do show up in the Graphic override char...
AC22 problem when zooming (scroll wheel)
I have a problem in AC22 when using scroll wheel to zoom it keeps resetting the view to a view seemingly where the layout was saved to a particular zoom even though i have changed the layout settings to 'ignore zoom and rotation when opening in this ...
  • 4784 Views
  • 10 replies
  • 0 likes
Best CPU for ArchiCAD?
I'm currently building a PC which shall be used fir ArchiCAD. What CPU should i go for? i7/9 or Xeon? If an image renders a little faster i dont care, workflow is more important. The PC might be used for gaming as well, but if Xeon is better for Arch...
  • 2684 Views
  • 2 replies
  • 0 likes
Copying objects between projects - bug
I'm having once a while a problem I can't solve. I copy a object from one file/project (eg wall) with Ctrl + C, switch to second file/project and when I try to paste it Ctrl+V it blinks for a second and disapears withaout pasting it. This happens in ...
  • 2814 Views
  • 6 replies
  • 0 likes
Resolved! Anyone using a Canon imagePROGRAF IPF670 Printer?
From what I've read... seems good when printing from the roll, BUT Is it easy to load precut sheets? - 24"x 36" (D in the U.S.) - 18"x24" (C) - 11"x17" (B) Do you have to remove the roll to do it? I assume there is no way to load multiple sheets of B...
