Setup & License forum
Forum Posts
Bizarre Dimension Glitch
I opened a file today and found very screwed up dimension strings that I had placed months ago. Some strings have morphed into include additional dimensions to the user origin, and on a different axis, which on some stories is simply out in space! Ha...
Crazy shadows in OpenGL window
This has been a recurrent problem since shadows have become a staple in the OpenGL window, and no one has ever explained to me why this is an issue. Whenever I open the 3D window it's a bit of rolling the dice. If I open it with a marquee or not, the...
Anonymous by Not applicable
  • 1475 Views
  • 3 replies
  • 0 likes
Issue with the Dimensioning
Hey, I have a very annoying problem. My dimensioning is crazy, but only the dimensions from door axis. I tried to find the issue, first it happens all the time when i published dwg files through the publisher.... Now i have the problem that some laye...
  • 1466 Views
  • 2 replies
  • 0 likes
Loading conundrum
For some reason in the last 1 week some of my AC21 updated pln files (these are legacy projects brought forward in many iterations of ARCHICAD) won't load. AC21 crashes after loading a library that I have warnings about being corrupted but have alway...
Best monitor for Macbook Pro
Hi guys, I've been struggling to find a 27 inch external monitor that deals with the "blurry text" issues with my Macbook Pro Retina and I figured I'd ask here to see if anyone has any recommendations. My budget is ~$500. Thanks!
  • 2571 Views
  • 2 replies
  • 0 likes
Add on - Wall accessories
Hi, I am new to ArchiCAD and have been using an educational license to learn on my own. I just installed the goodies package in order to use wall accessories. However, I cannot get the "customs settings" to work. It is disabled and grayed out. I want...
  • 2076 Views
  • 2 replies
  • 0 likes
AC 21 with 4K external monitor on MBP - Issues
I replaced my old 30" Dell monitor with a new U2718Q (27" 4K HDR) and began experiencing periodic crashes in AC. On day two I could not open a moderately sized pin without crashing. Working with Graphisoft tech support I eventually got the file opene...
cannot rendering because cinerender won't open
so I wanted to render, but there's a problem with cinerender and I don't know how to fix it. It said "cinerender by maxon has unexpectedly closed, u need to restart the archicad". I literally re - download again my archicad but it's still like that.
  • 6134 Views
  • 1 replies
  • 0 likes
