Setup & License forum
Forum Posts
Monitor Resolution
What Computer monitor resolution is recommended (works best) for use with AC21? 5K? 4K? 2560 x 1440? 1920 x 1080? One monitor? Two monitors? What is "your" monitor resolution? Respectfully - Greg
Anonymous by Not applicable
  • 5315 Views
  • 8 replies
  • 0 likes
Attempting to deploy ArchiCAD21 via PDQ deploy
Hi All I've recently aquired PDQ deploy. Ideally i'd like to package and roll out ArchiCAD to 150 odd machines. I've found an old graphisoft link to install ArchiCAD 14 with SCCM - but this isnt helpful. I'm after switches/parameters to install the p...
  • 970 Views
  • 0 replies
  • 0 likes
Archicad 21 Training
We're new here trying to find some good, comprehensive training materials that we can access online. I somewhat dumbfounded that there are not better resources out there. Why does Archicad charge extra for training on top of the expensive licenses? T...
  • 5734 Views
  • 14 replies
  • 0 likes
corrupted pln and bpn file
Hello, We had saved a file yesterday but today it could not be opened, neither the .bpn could be opened. It also failed to repair. on duplicating the .bpn it turned to 3.4GB (from 2.4 GB original size), While running the disk utility, it showed that ...
Surfaces display issue
Hi, I'm having a problem with one particular file that's displaying surfaces all wrong. See the attached image. The bottom image shows how this particular surface typically displays, and top other is in the problem file. Both pictures are from files ...
  • 4443 Views
  • 5 replies
  • 0 likes
Renovation filter warning ungroups pasted elements
Hi everyone! I've been a long time fan, thought I'd join in. First off, the default renovation status of elements to be modeled isn't fixed to saved reno filters (should be, imho). Instead, the default status shifts linearilly from existing, to demo,...
  • 969 Views
  • 0 replies
  • 0 likes
Updating several templates at once.
Hi, Our company is upgrading from AC19 to AC20 and we have a large number of templates (about 120) and I would like to upgrade the project preferences, attributes and masters without opening every job one by one. Is it possible to deploy a series of ...
AC21 MacOS High Sierra Performance Issues
I recently upgraded my OS to High Sierra and since then I have experienced a significant performance problem when editing text labels - stretching the text box, moving the pointer, mirroring, etc. Each time a command such as these is activated, Archi...
  • 4783 Views
  • 8 replies
  • 0 likes
