Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Archicad 18 and codemeter problems with IPV6
Hello everyone, I past my morning with tech support at boston. Excellent service. We did try to find out wy archicad 18 upgrade 5100 don't want to start. It seems that code meter have a problems with IPV6. Executing Broadcast for CodeMeter License Se...
Anonymous by Not applicable
  • 9063 Views
  • 3 replies
  • 0 likes
archicad 18 educational version
I am having trouble installing archicad 18 for education. While it is unpacking the software it will just stop. I have uninstalled version 16 and can re-install 16 without any problem but cannot install version 18.
  • 2410 Views
  • 2 replies
  • 0 likes
BIMx Viewer Windows 2008 R2
I'm trying to get BIMx Desktop Viewer 18 running on a Windows 2008 R2 Server. When I launch the application I get a black screen with the text "Graphisoft BIMx 18.3006 Viewer Version" then it crashes. It's a Virtual Machine running on ESXi that has a...
  • 2472 Views
  • 2 replies
  • 0 likes
Wibu or code meter key status
Did anyone know that you can't use your wibu or code meter key to work on different version Archicad 18. If i use archicad 18 US and want to use Archicad 18 French it doesn't work anymore. Why
  • 2223 Views
  • 1 replies
  • 0 likes
upgrade 5100 problems
Hello everyone, We did install upgrade 5100 us on imac an the server. But went we install on the Mac Pro cylinder archicad won't start it stop at the opening window (open a project or create) and then freeze there. Anyone have a clue Version 4006 wor...
  • 3043 Views
  • 5 replies
  • 0 likes
Cannot read plan file/Repair process failed/
Hello Hibaüzenet nélkül elmentettem egy fájlt. Másnap nem tudom megnyitni. Se a pln, se a bpn formátumút. Másik gépen, másik mappában sem. Hogyan tudnék hozzáférni egy heti munkámhoz, ami így bentragadt a fájlban, legalább részlegesen? I saved a file...
  • 14717 Views
  • 11 replies
  • 0 likes
ArchiCAD 18 Update
On trying to update I got the following report at the end [see attachment]. I have uninstalled and reinstalled to no avail. Also now at launching I get an error message stating that ArchiCAD wont start yet it goes on ahead to start. It is rather disc...
  • 1304 Views
  • 0 replies
  • 0 likes
PowerPC AC7 file to Intel AC18 DWG
Ok, I have an old file made in AC4 that I brought up to AC10, but it is still running on an old PowerPC Mac. How do I get it to be a AC18 file to run on an iMac and then eventually make into a dwg file to send to someone else. I bought a floppy reade...
  • 1503 Views
  • 1 replies
  • 0 likes
