Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1261 Views
  • 6 replies
  • 3 likes
Error, can't open file
I am having an issue everytime I try to open files from two specific projects. ArchiCAD runs through the library loading portion of the open, then displays this message: Error while loading plan file! Module: Attributes The options are to Stop Loadin...
Anonymous by Not applicable
  • 6899 Views
  • 4 replies
  • 0 likes
Library Loading Issues
Anyone trying to open AC 17 files in 18 and not migrating the libraries? Sometimes the library parts load sometimes they don't. Mac OSX 10.9.4 3.5 GHz 6-Core Intel Xeon E5 32 GB ram
  • 1501 Views
  • 0 replies
  • 0 likes
Plan space dissappears when panning
I just bought a HP Z800 that has a EVGA GTX260 and an ASUS 210 video cards installed. When moving the plan space in 2D the plan space goes all white while moving and for the last week I've been trying everything I know to do to get it to not disappea...
  • 1204 Views
  • 1 replies
  • 0 likes
Lenovo T540p
Hello All, I was a big fan of VAIO and since they are now discontinued I have switched to LENOVO. Just bough the T540p but I am not very happy with the screen resolution. It seems that when I work with Archicad the resolution drops down and becomes v...
ARCHICAD 18 INT FREEZE
Hi...i am testing the archicad 18 in demo version...and after about 15 min working the soft freeze...and i can not activate any bottom of the palette or close the program...but the operating system continue working...then i need restart window 7 and ...
  • 6987 Views
  • 7 replies
  • 0 likes
new mac pro
About to make the jump from windows to mac. Want to buy a mac pro. The flash drive that comes standard is 256GB which seems woefully small. The 1TB drive is painfully pricey. Which leads me to the 512GB option. Any suggestions as external flash drive...
  • 3623 Views
  • 3 replies
  • 0 likes
ArchiCAD 18 only installing demo
Hi, Installed ArchiCAD 18. Computer then rebooted without warning after what seems to be after installation (happened on every installation of ArchiCAD 18 ). After reboot ArchiCAD had been installed. However it is only allowing me to use demo mode. C...
  • 9686 Views
  • 7 replies
  • 0 likes
