Setup & License forum
Forum Posts
Resolved! no USB port for code meter key
Anyone dealt with how to plug in the code meter key when there is no USB port?Recently purchased a new MacBook pro laptop with the following ports: Three Thunderbolt 4 ports, HDMI port, SDXC card slot, MagSafe 3 port.Is the an adapter that the code m...
Archicad 22 and Monterey
I know AC 22 is not supported with Os X Monterey, but every time I quit, it crashes, and starts the boring procedure of bug report... is there a way to disable this?TIA, Federico
fcdehhh by Contributor
  • 563 Views
  • 4 replies
  • 0 likes
Archicad 25 Saves are taking longer on 2nd computer
IT guy here one of our employers switched to a different computer Custom Box i7-9700k 3.6ghz, 32gb ram, GTX 1070, SSD running Archicad 25 updated saves are taking up to a minute to save on the server. User was using a newer compact mini dell i7-10700...
Asmo by Newcomer
  • 382 Views
  • 3 replies
  • 0 likes
Keyboard Shortcuts
Hello everyone. I am using Archicad 25 Student Version and I have some kind of keyboard shortcut problem. "CTRL + i" command means intersecting the corners in the default version of Archicad 25. When I try to use that command nothing happens. So I ch...
