Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1356 Views
  • 6 replies
  • 3 likes
Archicad for windows with High res screens?
Just wondering if there are any plans to update AC to work well with high resolution windows machines? I just got a 3200x1800 laptop and I really like the screen. It's set to scale text and icons up and AC works just fine in that mode but since the g...
Anonymous by Not applicable
  • 5786 Views
  • 6 replies
  • 0 likes
added SSD to my Mac Pro - Very happy
In an effort to gain a little speed boost for my 2010 Mac Pro, I added a 488GB OWC Mercury Accelsior E2 as the boot drive. It has 2 SSD chips mounted on a PCI driver card which bypass the Pros built in HD nterface, so you can get speeds up to 688 MB/...
  • 3411 Views
  • 1 replies
  • 0 likes
Running Archicad 17 on Mac OSX Mavericks
Has anyone upgraded to OSX Mavericks and running Archicad 17? I have the student international version. I was wondering if the software ran ok on Mavericks. Im in middle of a project, so if anyone is experiencing trouble, I thought Id stay away from ...
  • 2840 Views
  • 2 replies
  • 0 likes
Composite editing
My composite editing window will not open any of the editing parts of the window. I can view them but I cannot change them. When I click on edit this item, it opens and closes as fast as it appears. Software getting old? Still on v12 and have done a ...
dahlsre by Newcomer
  • 2059 Views
  • 4 replies
  • 0 likes
Pln File won't open!
I downloaded a ArchiCAD file and when I go to open it all that happens is it just goes to the display screen. I have had the file resent to me and I still have the issue. Please help!!!!!
  • 1669 Views
  • 2 replies
  • 0 likes
Unable to install Archicad 17 / Win 7 64
I have downloaded (multiple times now) the Archicad 17 installation file for windows 64 bit from MyArchicad. Each time I have, about 15 seconds after I click on the file to begin installation, I get an error. See the attached image. I am running Wind...
  • 2352 Views
  • 1 replies
  • 0 likes
Problem installing my ArchiCAD 17
Hi, I am Elvin. Currently study in UK. I cannot install my ArchiCAD 17. Im using Asus N56VZ which operated Windows 8.1. At first when i install my ArchiCAD, it will stop at the page in attachment 1.jpg . I try to click next but still in the same page...
  • 3382 Views
  • 1 replies
  • 0 likes
AC Build 4008
I got a message that my AC17 was out of date and downloaded the Hotfix3 build 4008, but when I go to install it on the BIM server it doesn't update. When I check for updates on the BIM Server, it says it's up to date. I won't install this on the loca...
  • 2990 Views
  • 5 replies
  • 0 likes
