Setup & License forum
Forum Posts
Archicad Licence was not found
If anybody could help me, it would be greatly appricated. I have been trying for two evenings without luck to get Archicad 17 to work on my home computer as well as my work mac to get some work done at home. I have come to the conclusion that codemet...
Anonymous by Not applicable
  • 8789 Views
  • 2 replies
  • 0 likes
Morph vanishes in 3d edit
Hi. I'm trying to get my head round using the morph tool but for some reason when I try to use the tube or some other tools in 3d the morph disappears. It seems to work fine with the internal rendering engine but not openGL. I've used it to model gut...
  • 2429 Views
  • 2 replies
  • 0 likes
dongle hierachy
howdy we have the following situation - 5 people are using archiCAD v16 connected to a network key - 1 person using v11 with a local usb dongle problem is… the user using v11 often takes a network key when Ist launching archiCAD… which obviously mean...
  • 4156 Views
  • 5 replies
  • 0 likes
Mouse Recommendation
I'm looking for a recommendation for a good mouse that will work with AC. I used to use the "Mighty Mouse" by Apple but the little roller ball gets gunked up on me after much use and is hard to clean. I've been using a Logitech M305 mouse (now on my ...
  • 5039 Views
  • 2 replies
  • 0 likes
ArchiCAD 17 Crashing Issues
I have recently run into an issue with ArchiCAD 17 crashing in two different scenarios. The first; when attempting to place an external image into an existing project. The program crashes and quits, then opening the bug-manager. When the project is r...
  • 1517 Views
  • 1 replies
  • 0 likes
Old versions of AC on Windows 8.1
You can try but there is no guarantee it will run. AC 16, 17 and 18 are the only officially supported ArchiCAD versions for Windows 8.1: http://helpcenter.graphisoft.com/technotes/operating-systems/compatibility-notes-to-archicad-on-windows-8-1/
Archicad 16 very slow in 2D
I am currently using Archicad only for 2d work and it takes ages to upload all elements in a plan or switch between levels. The description of my computer is contained in the signature. What could I do? Thank you.
  • 4747 Views
  • 7 replies
  • 0 likes
AC17- 6004-hotfix7 on a Mac OSX 10.7.5
I have downloaded the hotfix but when running the installation wizard I get an error message: ArchiCad 17 Hotfix #7 cannot access one or more files in Macintosh HD:Applications:Graphisoft:ArchiCAD 17. What do I do now to install the hotfix? Jane Mac ...
  • 2731 Views
  • 3 replies
  • 0 likes
