Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1356 Views
  • 6 replies
  • 3 likes
GRAPHISOFT OR APPLE PROBLEM
Purchased a new mouse (apple with cord and tiny track ball) to replace the apple "Magic Mouse", but am having the same problem, only in ArchiCAD. When I move the mouse (either of them), the arrow does not show on the tool bars, or when trying to sele...
Anonymous by Not applicable
  • 1364 Views
  • 0 replies
  • 0 likes
Selecting mesh/fills/slabs
Does anybody else have issue's in AC16 when 2 slabs or meshes or fills touch each other you select 1 then try to click on the outer edge to add a node or stretch etc. but you cannot select the one you want, but if you select the one next to it, it wo...
  • 3977 Views
  • 4 replies
  • 0 likes
File Size
Hello everyone, My question is how around 500 (3D and 2D) pcs. viewports change the size of the file ?
  • 1572 Views
  • 0 replies
  • 0 likes
Really slow startup
O my new laptop ArchiCAD (v. 13-16 all of them) starts up really slow. Actually way slower than my old desktop – it takes 1,5 mins to get the splash screen showing. It's really slow considering that the laptop is a 2.6GHz quad core retina MacBookPro ...
  • 12273 Views
  • 7 replies
  • 0 likes
Open GL antialiasing
Hi folks! My laptop returned from the repair (fix a Hard Disk S.M.A.R.T issue) and, after that, the Open GL hasn't good resolution: it presents certain lack of antialising, the shadows too. The 3D feedback for Split commands and the 3D plane dont app...
Plug in Directory
I can not download Interior Wizard! I down loaded Interior Wizard and used it for ceilings on my last project. I can not find it associated with this project. How do I find the Plugin Directory? Message received when try to download: X Free Download ...
  • 4970 Views
  • 6 replies
  • 0 likes
Plan to 3D Window to Plan Returns to Wrong Story
I was wondering if anyone else had encountered this odd behavior. It's happened to me on previous versions of AC and continues to happen in v15. I'll be working on the floor plan on Story 3. Then I'll go to the 3D Window to check out the model, then ...
genarch by Booster
  • 2543 Views
  • 2 replies
  • 0 likes
A problem with installing HOTFIX 6 for AC14
Hello! Sorry if this question was already discussed, coudn't find it. The problem is that after installing the AC14-4204-HOTFIX6-WIN64 I get the following message: "The procedure entry point could not be located in the dynamic link library Teamwork....
  • 2619 Views
  • 1 replies
  • 0 likes
Date stamp incorrect
I just found an anomaly with Archicad file. Earlier this month I revised a drawing from June of last year. However when I when to open it, the file date was listed as June 28, 2012 even though it had been revised Jan. 21, 2013. I opened the file agai...
