Setup & License forum
Forum Posts
AC17 Texture display problems in 3D
Hello, I have problems working on AC17 with textures display in 3d mode. I am attaching the printscreen on the problem. Archicad is up to date, the video card drivers are up to date as well. Opening projects in Bimx also causes problems... Small deta...
Anonymous by Not applicable
  • 1305 Views
  • 0 replies
  • 0 likes
Info text in option tabs sometimes hidden.
Hello, Several times since using AC I have seen that information texts are hidden or almost invisible in setting menus, GDL settings (especially with Add-on GDL), Now Morph tool. This is not a big deal, however I am curious what is the source of this...
  • 1353 Views
  • 1 replies
  • 0 likes
Poor Regeneration Performance
Hi everyone, Using ArchiCAD 16. having some real issues with performance in regenerating sections, 3d, and viewpoints on layouts. I've built multiple models from start to finish and this model has gotten bogged down faster than any other. Its a 6000 ...
  • 2621 Views
  • 4 replies
  • 0 likes
Cant get ArchiCAD 17 installer to work
I have not been able to install ArchiCAD 17 from the DVD as the program would stall. I can install directly from within the DVD by clicking on the .exe file. The problem now is that the hotfixes don't install. I have updated to the latest Java and al...
  • 1471 Views
  • 0 replies
  • 0 likes
Hot fix 4010
My system confirms I'm running 64 bit windows. However the hot fix says application can't run because it's not a valid 32 but application.
  • 3673 Views
  • 6 replies
  • 0 likes
IFC translators crash
Good morning/afternoon/evening (depending on your location)- I am having a problem whenever I open and work in the IFC Translation Setup while in Archicad 14. The only translator I have when I open the Setup is the General Translator. I am able to ad...
  • 1583 Views
  • 1 replies
  • 0 likes
