Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1253 Views
  • 6 replies
  • 3 likes
Slab Editing
After 20 years of using AutoCAD I am new to Archicad. Please bear with me as I ask what must be very basic questions to some of you. I purchased the educational version of ArchiCAD 9 a couple of years back. I purchased Virtual Tutor 9 at the same tim...
Anonymous by Not applicable
  • 9207 Views
  • 15 replies
  • 0 likes
AC 12: Where's my audio feedback?
OK, I give up. Where are the user feedback sounds? The little honks, chirps and bleeps that inform you that you have successfully sucked up attributes or injected them or that the 3D window display is progressing, ect. All of these, on my system at l...
Chazz by Contributor
  • 3654 Views
  • 4 replies
  • 0 likes
Dual monitor problem
My AC doesn't seem to like the idea of being used on a dual monitor system and I'm wondering if anyone else has this problem? I'm using a MacBookPro and my second monitor is a Wacom 21" Cintiq (so actually it's more than just a monitor). I have to ha...
  • 1646 Views
  • 0 replies
  • 0 likes
MAC OsX: ArchiCAD shortcuts vs system shortcuts
I'm new with Mac OsX. I just start this week. My problem is that I configure shortcuts with the F keys, and when I pres the F buttons, they respond to the system shortcuts instead the ArchiCAD ones. Would anyone tellme what's wrong? Thanks in advance...
  • 2521 Views
  • 3 replies
  • 0 likes
Archicad 12 "No Protection Key Found . . ."
I just received v12 in the mail today and tried to install in on my Mac and my PC and got the same error message "No Protection Key Found or Not Valid" when I tried to run it. I thought my key may have been bad so I tried running v11 which worked jus...
  • 12980 Views
  • 8 replies
  • 0 likes
Wall End
Good evening Can you please provide the informations about the wall end command how can i use (could you guide me)
  • 1679 Views
  • 1 replies
  • 0 likes
Enclosing space under stairs
I would like to create a wall to enclose the space under a staircase. The wall would be the height of the other interior walls on one end but would follow the slope of the stair carriage to a height of about 7" on the other. I can't find how to accom...
  • 5426 Views
  • 7 replies
  • 0 likes
Mac multi-core vs PC multi-core
Does anyone know if there is there a fundamental difference in the way a Mac computer uses multiple cores, as opposed to Intel PC, which will dramatically affect processing times? My computer guy seems to think so and is keen to have me make the swit...
