Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1378 Views
  • 6 replies
  • 3 likes
Library part not converted properly
I have opened an archived project from 2001. I am using AC9. There are several random objects that bring up a dialog box: "Library part was not converted properly (Obj -###)" When I go to 3D window. Selecting "Stop" brings up a black window. Selectin...
Anonymous by Not applicable
  • 3705 Views
  • 4 replies
  • 0 likes
Serious installation issues
Really hope someone can help me. i downloaded the norwegian trial of ArchiCad 11 and started the installation. eveything seemed just fine until the very end oif the installation. The installer "hangs", even though its running, on "registering ArchiCa...
  • 2839 Views
  • 4 replies
  • 0 likes
column and wall intersection help
Hi guys, I have been having trouble with my walls once I place a column in them (used to present a rotating door). The walls end up having a piece of them removed when I place the column inside them. Not just the circle part but an entire section. Ev...
  • 1890 Views
  • 1 replies
  • 0 likes
Loss of sound feedback
AC10 (1188) on Mactel has lost tool audio feedback on extant files and new files. System sound is OK. What's up? Thanks for any vector.
  • 2838 Views
  • 4 replies
  • 0 likes
Doors above GFL
Another simple quesion, I've been trying to create a door at FFL but every time i do this it appears at GFL? how do i change this? Thanks
  • 2987 Views
  • 5 replies
  • 0 likes
Chimney Breast
Hi, Can you please let me know how to add chimney breast onto an existing wall. I'm on PC running XP O/S. Dell Dimension PC
  • 3193 Views
  • 3 replies
  • 0 likes
Really slow ArchiCAD 11
Hello guys, I'm new on this forum and I'm having a big problem. I've searched all over the forums. I found the thread with ArchiCAD 10 crashing on startup, but that's all, and it doesn't really help me since I don't have these files in my system fold...
  • 3049 Views
  • 3 replies
  • 0 likes
