Setup & License forum
Forum Posts
New Logitech 3200 Mouse and Keyboard
I have installed a new Logitech Mouse 3200 LX and keyboard and when I use the middle button to zoom in or out, the PLN file goes all over the place before settling on one spot. Also the Pan feature is not working. I remember this problem when install...
Anonymous by Not applicable
  • 2444 Views
  • 3 replies
  • 0 likes
Multi-display support
Hello folks. Is there a way to make 3d/section window leave main archicad display ? Because i cant use my second monitor for displaying anything except toolbars. Its a bit strange if you ask me. So, maybe i'm missing some setting that needs to be cha...
  • 4175 Views
  • 5 replies
  • 0 likes
idle CPU issue
Compared to other bugs in the program this is insignificant, but I noticed if I run the app Activity monitor - i can see Archicad and MS word consume CPU even when in the background and idle. (about 6% each). I feel cheated EDIT: using a later versio...
Program crashes when in Open GL mode
The program shuts down. Open GL seems to be the problem. I tried using my older computer and had similar problems when I switched from the Internal engine to Open GL. I have dual monitor setups on both computers. My current setup is: Processor: Quadr...
  • 1359 Views
  • 1 replies
  • 0 likes
New I Mac/ Arch 10 problem
I just got my new I Mac 24, and it is beautiful. When I try to load my A Cad 10, it gets to the Install Shield screen, and sticks there. Is there a conflict, or a trick I'm missing? Thanks.
  • 1501 Views
  • 1 replies
  • 0 likes
ATI FireGL new graphics card
Is anybody else using the new v7350 1gb card from ATI??? If so what driver are you using, and is it reported as being fully compatible with ArchiCAD?? This is on a PC with Version 10. Thanks Tom
  • 1521 Views
  • 1 replies
  • 0 likes
Quad core and Archicad 10
I am considering getting an Intel Core2 Quad Q6600 processor with Vista Business 64. Until Archicad get their house in order with Vista, I'll be using XP Pro64 OS. Will Archicad run OK with this hardware and OS? Will new versions take advantage of mu...
KeesW by Enthusiast
  • 1995 Views
  • 1 replies
  • 0 likes
!Restored: AutoCAD convert's questions
Hello. New here, new to ArchiCAD. I have been working on ACAD for many years now. Mostly 2D layouts. Whatever needed 3D has been done in MAX. But now i'm thinking stepping up a bit and doing most of the stuff in 3D from the start. I have a big proble...
  • 8547 Views
  • 17 replies
  • 0 likes
