Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1369 Views
  • 6 replies
  • 3 likes
Important Apple Message
Apple has just posted a warning message re the use of FireWire 800 HD with Panther: http://www.apple.com/macosx/firewire800specialmessage.html In short: stop using them right now before losing data. Cheers Francois
Anonymous by Not applicable
  • 4061 Views
  • 1 replies
  • 0 likes
Weird crashes- Intellimouse driven?
Anyone having crashes unexpectantly when using AC8 R3 with Microsoft Trackball mice? We have 2 workstations in the office that seem to crash when dragging, rotating, stretching paremetric objects. Or is it the NVidia GF video cards? All have latest d...
  • 7689 Views
  • 7 replies
  • 0 likes
8.1 Doors changing parameters
I'm having problems with doors changing paramenters. I have inserted door D2 from the 8.1 library and set the parameter to H-V Grid. This seems to work for a while in the 3D window (Open GL) but after a while the door has reverted back to show no gri...
  • 6845 Views
  • 5 replies
  • 0 likes
has this slowdown bug been fixed in 8.1 (OSX)
Hi, Since version 7 the more i generate 3d views the slower the proceedure becomes until I am forced to restart Archicad. Is this an issue with version 8.1 or can anyone enlighten me as to a workaround. Indeed is this a problem for other users?
ArchiCAD on a slower PC
I have been running ArchiCAD 8.0 & 8.1 with satisfying speed and responsiveness on my older PC: Pentium III 600 MHz 256 MB RAM Geforce 256 DDR (32MB) Windows XP Pro (which eats memory) Anyone satisfied with even lower specs? I don't do large projects...
stefan by Booster
  • 7018 Views
  • 5 replies
  • 0 likes
Key plug problems on OS 10.3
Just wondering if any one has had problems with their key plug on MAC OS X.3 and ArchiCAD 8 V3. I know I know install ArchiCAD 8.1 but the Swedish version isn't done yet: If so what was the problem and was there a fix?? Cheers..
