Setup & License forum
Forum Posts
Teamwork Reservation Problem
We can't seem to get Teamworks to let us reserve portions of the drawing the way we want. This is the scenario: Using the marquee, one drafter can sign in and reserve the marqueed area and the necessary layers, but if he also reserves Floor 1 nobody ...
Anonymous by Not applicable
  • 3791 Views
  • 1 replies
  • 0 likes
3D Modeling
When creating a custom circlular window and using it in my model I have discovered the object defines a square as the rough opening for the circular window and places the window within the square leaving the wall between the window edge and the squar...
  • 5563 Views
  • 4 replies
  • 0 likes
Tiff not opening --- HELP!!!!!
Has anyone ever had a problem with a tif file not opening after it was burnt to a DVD? Where I work we had about 250-300 jobs where each had scanned images of the working and preliminary drawings. Now that they have been burnt to a DVD I went back to...
Red by Enthusiast
  • 5363 Views
  • 4 replies
  • 0 likes
This should probably go under Tweaks...
FYI, if you want to get every last morsel of computing power from your machine, I would highly recommend downloading the following program: Xteq X-Setup approx. 6.4MB I have been using it for months and it's always the first program I install on ever...
  • 5248 Views
  • 2 replies
  • 0 likes
ATI vs nVidia
Greetings all, I'm new here. In fact, I don't even have ArchiCAD, my dad does. We just installed 8.1 on a new system I built for him: 3.0 GHz P4 w/HT 800 MHz bus 1024MB Dual-channel DDR400 RAM (2x512) Dual 40GB 7200RPM hard drives WinXP Pro All softw...
  • 5195 Views
  • 3 replies
  • 0 likes
Powerbook 1 GHZ vs. 1.33
Does anyone have any experience comparing the two latest Powerbooks using AC? I'm wondering if the difference in processors and graphics cards are significant.
PowerLogix 1.4GHz Upgrade--Very NIce
For anyone with a Mac as old as mine (Sawtooth 500) you might be interested in this. I installed a PowerLogix 1.4 GHz upgrade card ($436 from owcomputing.com) and the results are just great. I've included some comparative test times below. This will ...
Text and Label shortcuts swapped
This is just a bug report. If you check out the keyboard shortcuts list it shows the Text shortcut as "K" and the label shortcut as "Shift+K". However, they are exactly the opposite -- the list in the shortcuts editor needs to be fixed.
  • 3364 Views
  • 0 replies
  • 0 likes
Extremely slow navigation times!!!
Thank you to everyone who has posted comments on this already. It is just driving me crazy and I have not gotten anywhere with it. It is really causing major headaches for us. We keep all of our project files on our server. This is common practice. W...
  • 13123 Views
  • 12 replies
  • 0 likes
Dimension Strings Disappearing at the Eleventh Hour
Here is a post I submitted to tech support last night that might be interesting to know. Has anyone else had the same occurrence? "Today my partners and I were all working on final coordination before we issued the job for bidding. This 1.5 Million d...
  • 5074 Views
  • 3 replies
  • 0 likes
