Setup & License forum
Forum Posts
Downward Extrusion in 8.1
This is an example of a roof and slab with a downward extrusion. It does not cut all the way thru the slab! Surely this is not the correct outcome for this tool. Any ideas? I have worked around by just making the roof thick enough to remove the porti...
Anonymous by Not applicable
  • 9517 Views
  • 7 replies
  • 0 likes
8.1 Library problem?
New install on OSX.2.8. Upon first launch and creating new project (default settings) I do not have complete libraries—no doors or windows for example. I have tried opening an 8.0 file with attendent libraries, and still same effect. What am I doing ...
  • 6609 Views
  • 4 replies
  • 0 likes
OS 10.3 Dock's and A.C "Drag a Copy" => same sh
If you've experienced the same problem as I did with the A.C short key for "Drag a Copy" not functioning while the Mac OSX "Dock" kept on popping up and down instead, then here is one solution to your problem: Check off the Dock short key command set...
  • 3286 Views
  • 0 replies
  • 0 likes
video card help
I have a friend whom has a sony pc and is having trouble with his 32 meg video card. It is obvious that we need a 64 meg video card, but I was wondering why it is giving us the result of blank drawing windows in plotmaker. It still renders in archica...
  • 4396 Views
  • 1 replies
  • 0 likes
Interactive Schedule
I'm embarressed to admit I haven't explored this sooner - anyhow I just want a tabular list of zones on the floor plan listing areas - and it all works well except for some annoying numbers I cannot explain - refer screenshots - to the right of the a...
  • 6404 Views
  • 5 replies
  • 0 likes
phone support?
Is there a number for phone support? I'm from the US (Oregon), and can't seem to find one. Thanks, Lori
  • 5847 Views
  • 3 replies
  • 0 likes
PC or Mac
My office is about to buy new computers. I am looking for input as to which computers to buy. Is it worth buying a new G5 or should we buy new PC's? Is the 32 bit hype worth the money? Does Archicad run better on PC or Mac? Thanks
  • 16408 Views
  • 14 replies
  • 0 likes
Dual monitor w/ Laptop
For those using a dual monitor setup with a Laptop, how is it when you are only using the Laptop LCD (say on the road) is it difficult to set up the AC screen environment with every thing on "one" screen again? And then back to "two" once "plugged in...
  • 5057 Views
  • 2 replies
  • 0 likes
!Restored: Annoying ArchiCAD sounds!!!!!
I think someone once offered how to turn off the annoying ArchiCAD sounds without turning off your computer sounds, or better streaming music. I hate hearing all the "beeps" everytime you command click on something or pull up a 3D view, only to have ...
rm by Advocate
  • 10102 Views
  • 10 replies
  • 0 likes
