Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1253 Views
  • 6 replies
  • 3 likes
Archicad 19 install issue
I have recently tried to install archicad 19 on my laptop, at the end of the installation process my desktop starts flickering and all commands freeze. I can only acces task manager through shortcuts and i managed to uninstall it, fter this the issue...
Anonymous by Not applicable
  • 1339 Views
  • 1 replies
  • 0 likes
Archicad with iPad Sidecar Display
I have major problems with Archicad whenever I attempt to use my iPad as a second display with Apple Sidecar. Archicad is unable to open any floor plan, all favorites and object thumbnails are solid black, and Archicad continues to crash. Is this a p...
3D Model View Frozen
Strange problem has appeared on one of my projects where navigation in the 3D view is not working at all. I can open the 3D view, but zoom, orbit and pan are not working (the pan hand and orbit symbol replace the pointer when activated, but no naviga...
AMD Ryzen 9, AMD Threadripper or Xeon W ?
What is the most suitable CPU for AC 23 (large projects and extreme performance)? 1) AMD Ryzen 9 3900X (12c / 24tr, base clock 3.8, max boost clock 4.6; DDR4 3200; PCIe lane 4.0; 70 mb total cache or 3950X (16c / 24tr, base clock 3.5; boost clock 4.7...
  • 2271 Views
  • 4 replies
  • 0 likes
install Archicad 10 file converter
Archicad 10 file converter does not work without having Quicktime installed Apparently it was last used in version 17 archicad Apple has discontinued windows version so how or where can I get a quicktime installation file - so that I can install the ...
RandyC by Booster
  • 1070 Views
  • 3 replies
  • 0 likes
Yosemite iMac won't run AC23
All - my 2012 iMac running Yosemite 10.10.5 system software cannot be upgraded to run AC23. Does anyone know if there is a hardware part (CPU maybe) that can be changed out so latest Apple OS can be installed?
lagodue by Newcomer
  • 1667 Views
  • 3 replies
  • 0 likes
AMD FX 6300
Recently my husband built his new pc and his old cpu that is perfectly working is available to use.The cpu is AMD FX 6300.Can i built temporarily with this cpu a new pc with a good graphic card and memories in order to work with archicad 22?which gra...
  • 1484 Views
  • 4 replies
  • 0 likes
