Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1261 Views
  • 6 replies
  • 3 likes
Software key and Mojave
I recently updated to Mojave and now have an issue where my software key always needs to be uploaded and repaired each time the Mac is restarted. Then re-downloaded to use ArchiCAD. Any ideas on how to fix this would be appreciated. Thanks.
arg617 by Participant
  • 1407 Views
  • 3 replies
  • 0 likes
Text simplifying during zooming
I want the text blocks become simplified not so fast, as it's by default! I found that if one text blocks has a big text and small, small text can be not simplified at all! For me it is more comfortable to have full view with no simplifying or with s...
Anonymous by Not applicable
  • 593 Views
  • 1 replies
  • 0 likes
AC 22, 4k Screen, Windows 10, Cursor very small
Hi there, the Archicad cursor is insanely small on my 4k screen. I found a way how to fix the problem in the Graphisoft Help center. https://helpcenter.graphisoft.com/knowledgebase/74887/ But the Cursor becomes small again after each PC reboot. Is th...
  • 736 Views
  • 2 replies
  • 0 likes
Archicad 22 stuck on Refreshing the screen
Having troubles with Archicad 22 stuck on Refreshing the screen. Only occurred this morning after computer went into hibernation mode. Have reinstalled again and completely updated. Happens on every file so I can't use it all. I have updated all my U...
  • 1418 Views
  • 5 replies
  • 0 likes
A Dark 3D View
Hi, I am having problems with my 3D view. When I first clicked on the 3D tab, my 3D view is pretty dark although I can still see the blue lines in the model. When I click on the right button, scroll or drag the model around then I can see the 3D view...
  • 2841 Views
  • 8 replies
  • 0 likes
silent mac uninstall isn't
I'm trying to remove AC20 from a suite of laptops, hopefully programmatically. I've just tried to run the silent uninstaller by hand using sudo in terminal, and the app still pops up an admin prompt. Here's the commnad I'm using: sudo "/Applications/...
  • 893 Views
  • 0 replies
  • 0 likes
3D connexion buttons
I have the buttons on my 3d connexion mapped as key board strokes but they perform seemingly random zooming functions. Any idea how and where a problem might be? Mac - Archicad 22
Narska by Enthusiast
  • 4687 Views
  • 12 replies
  • 0 likes
