change version Archicad english to Archicad russian
tlenor
how to change version Archicad english to Archicad russian
7 REPLIES 7
Eduardo Rolon
You will need to download the russian version from GS website. There is no way to change versions.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Miha_M
@Eduardo Rolon but I don't think it will work it's on a hardware dongle license. The licence is localization dependent, isn't it?
@tlenor is Archicad running on a Codemeter dongle or is it some other license type?
| Archicad 4.55 - 27
Eduardo Rolon
AFAIK License does not discriminates between versions, with my Codemeter I can run INT, USA and when I could download, SPA.
AC27 US/INT -> AC08
another Moderator
Miha_M
I had to install the GER localization to get the GER library as I was helping solving some problems  on a Germany based project. I tried to run the GER localization on my INT license. It didn't work.
| Archicad 4.55 - 27
I think it might be language dependent.
I run AUS but can also run other English language versions - INT, USA and I think I might have tried UKI once.
But I tried the French version once and I could not run it.
Maybe because you are in a multi-lingual area, you might get the option of more languages.
If the original poster has a legitimate Russian license then he may be able to download and install the INT version - I think everybody gets to use that (I am not 100% sure though).
But if he has an INT version (or other English language version) then that may be all he can run (apart from other English language versions) - but again I am not 100% sure.
I think the GER/CHE/AUT versions all are in their separate tier - they have some additional, regionally specific features developed in there. The INT version seems to be accessible with most keys (I have a hardware key for the HUN version).
I'm curious: is there a chart about which keys are "compatible"?
+1 It would be helpful to have an inventory of the different libraries, not to have to install a specific version just to get it...
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
That was one of my wishes, a global SSA Database.
Global SSA Database - Graphisoft Community
| Archicad 4.55 - 27
