Installation & update
code meter key
I am trying to newly install AC start 12 on a windows 7 64 bit computer and encounter no valid license key found (111). I have tried installing drivers for windows, but have not had any luck. Any suggestions?
1 REPLY 1
Assume you mean Start 2012. Start runs by year numbers while Pro runs on version numbers. Did you install with the key UNplugged - and not plug it in until after rebooting?
If you re-installed the Codemeter driver, is it this one:
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Learn and get certified!
