windows installs codemeter for windows into start folder , is this necessary to run on wibu key (not codemeter key ) Can I remove it from the start menu ?
You need only the dongle driver that matches the dongle you use.
If you use a Wibu fongle, you don't need a Codemeter driver, you can uninstall it.
My question is how did the Codemeter driver be install if you chose the WIBU key option at installation.
.................................................................................................... Get Archicad Tips at https://twitter.com/laszlonagy AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25 Loving Archicad since 1995
