Hi Mike,
Data Transfer Rate (actual, not theoretical) is the key factor, not rotational speed. Unfortunately, few manufacturers/vendors post actual DTR info.
All things being equal
...faster RPM 'usually' is better, but all things work together, and all things are rarely equal.
As you increase the drive capacity - for a drive with the same physical dimensions and design [your case I believe] - the density of the data on the surface increases, and thus bits 'fly' by the read/write head faster simply because of density...so, a slower RPM higher capacity drive may very well have the same DTR (or better) than a higher RPM lower capacity drive [assuming the same physical read/write head / platter configuration].
The amount of on-drive memory cache, and the entire controller hieararchy (on-drive circuitry, computer bus design, OS, etc.) also impact DTR greatly. (A high speed drive that cannot read the next sector on the same revolution because controller hierarchy cannot process the data fast enough will have to skip a revolution - making the high RPM irrelevant.)
As consumers, it is really frustrating for us because we want to know DTR of a particular drive in a particular system...and the retailers, whether Apple, Dell or whoever, do not share this info. Lots of Googling and finding users who have run benchmarks seems to be the only solution that I know of today.
Karl
PS Later this year, drives with HUGE disk caches are supposed to start appearing. So, rather than 8 MB as a typical on-board disk cache, it will be in the GB's. These should improve performance dramatically, but I believe the first drives will only be in desktop sized units.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
