Setup & License forum
installation problem Archicad 24
SaraSimons
I'm using Archicad 24 student version on my old pc.  Now I have a new (more powerfull) PC with the same operatingsystem (windows 10).  While installing (Archicad-24-ned-3008-1.0) I receive the message that my operating system is out of date.  troubleshooting isn't helping.  Any suggestions?
7 REPLIES 7
This article might help ... https://community.graphisoft.com/t5/Setup-License-articles/Archicad-23-Install-and-Startup-Troublesh...
Versions 6.5 to 25
I read that article and done all the steps suggested but it didn't resolve the problem.
So you have tried to install all of the 3rd party installers listed here?
https://community.graphisoft.com/t5/Setup-License-articles/3rd-party-installers-for-GRAPHISOFT-produ...
I had a similar problem once and installing these and restarting, then installing Archicad again helped.
I am not saying it definitely will in your case, but I am pretty sure it is a case of your Windows operating System not being up to date.
Versions 6.5 to 25
yes, i have installed all 3th party installers, i have full installation rights and it's a brand new PC.  Everything is up to date.  i've restarted and the installation keeps getting stopped.  i bought this pc becauce my old one had the minimum requirements and was to slow.
I am not sure what else to suggest other than searching these forums for other "out of date" posts.
As a student, you should be able to contact your local Archicad distributor and ask for help - at least I hope so.
Versions 6.5 to 25
i'll contact my local distributor (kubus) and hope they can help.
Tnx
Sara
Buying a new computer doesn't mean it's up to date out of the box,
You probably have but make sure you don't have any windows updates, sometimes they are published once a week sometimes once every other day of something was borked.
FREE Soffit & Fascia for Rail Tool - https://bit.ly/BIMRithmSoffitandFascia
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
