Installation & update
installed 9, now can't run 8.1
This seems to maybe be a key issue?
I installed 9, upgraded the key, and AC9 will run but now 8.1 will not start. I get the starting screen graphic and then the spinning rainbow wheel and can only force quit out. Downloaded wibu key update from the support page, tried re-installing 8.1 (then updating to v2) and running the wibu update all to no avail.
thoughts?
Thanks!
Katie Bertsche
Mac 1.2g G4, OSx.3.7
7 REPLIES 7
__archiben
just a thought:
you're not trying to run them simultaneously are you? one key will run many sessions of the same version, but not of multiple versions. i.e. you can only run 8.1 or 9 - not both together . . .
any good?
~/archiben
b e n f r o s t
David Maudlin
Katie:
I do not have a solution to your problem, but contrary to Ben's reply, I can run both ArchiCAD 8.1 and 9.0 simultaneously on the Mac.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I wasn't trying to run them both at the same time, but we figured it out...I had to throw away all the old 8 and 8.1 preferences and problem solved. Should have thought of that first.
Hopefully everything will work fine now
Thanks!
Katie B.
__archiben
with only one key? or do you have a network license?
~/archiben
b e n f r o s t
I just tried and I too can run AC8.1 and AC 9 together on one key. It is an individual USB key.
David Maudlin
Ben:
I have only one key. I also have a PowerBook similar to yours that I used to verify this (FYI I am able to open ArchiCAD 9.0, 8.1 and 7.0 simultaneously on the one key). I am surprised that you cannot do this as I cannot remember a time when the ArchiCAD key wouldn't run multiple versions simultaneously (previously Graphisoft supplied updated older applications when the key needed to be exchanged). I wish I could give you some ideas, but I haven't done anything unusual to get both versions to run. When you have one version running, what happens when you launch the other version? I am also curious if other users are having your experience or mine. HTH.
Eduardo Rolon
No problem here running both AC8.1 and two AC09 sessions at the same time.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
